Originally Posted by MRM RCModels I checked for run out in the tool holder: less that 0.001 at full rpm. What did you mean by check to tool diameter? Do you mean in Mach 3? |
May be the case... if u gave the tool dia 3mm in ur CAM program and actually the tool u are using in ur machine is 3.2mm also with a little bit run outat the tip of ur tool.....u will be having the same trouble..
just my 12 x 70000/12 cents...
