Crevice Reamer!
Please tell us the MAX depth you can go with your 3" 5 cutter Face Mill?
Feed rate & RPM?
If you look at a BRIDGEPORT Milling Machine. Is it gear drive or belt?
There is a reason why the Big boys use what they use.
I have used a Sherline Milling Machine for over 8 years.
Bottom line im sick of the belt not lasting. And the preformance of it sucks.
Plus everything about a Sherline is over price.
After I get my X2 MOD the way I want it. I will be selling the Sherline.
No more belts to replace for me.
Yes the belt will ether slip or break befor a .5 end mill will.
Then again if your making a cut that deep and too fast feed rate.
Your motor will be getting HOT real fast. You may end up burning up your motor befor the belt breaks. So there are good & bad points for ether type. |
