Hello X7racer, You can fix the "ERROR- WRITE NC OPERATION INFORMATION MUST BE ENABLED IN CONTROL DEFINITION - SET AND REPOST" message by going into the "Machine Definition Manager" then select the Edit Control Definition Icon. when there, under the Control topics select the Files topic. On that page you will fine a check box that says NC paramter file. Make sure that you have a check next to the Write NC operation information. Also make sure that just below that the Source ops parameters only is selected. This shoud get rid of your eror message.
I have also reworkd a .pst file that i use on a VF-1, VF-2, VF-E and a TM1P that seems to work much better. I can e-mail this to you if you'd like to try it out.
Lyle |
