Yes the mill is still stock!! The spindle motor just takes off running. What im thinking happened is some metal shavings got on the speed control board and burned something out. Lathemaster was shocked to hear the Estop was non functional as was I. Im taking the whole assembly apart and mounting it in a seperate enclosure to prevent chips or fluid from entering, but I just think its to weird that it would be capable of running with the e stop pressed or even the wires un hooked. |
