I'm not familiar with the Dynapath 10 control but I had a old anilam control that the z-axis limit switches were bad. If you had the z-axis next to the mechanical upper limit when you homed the machine it would only rock the z axis back and forth and set that position as home. At that time all of the soft limits would set and the machine would be referenced. May be the trick your looking for. |
