Old 08-18-2004, 11:25 AM
Jim Stein Jim Stein is offline
Jim Stein is on a distinguished road
Handheld Plasma Cutter with CNC?
I have a Hypertherm 380 hand held plasma cutter and I also have a homemade CNC Router. The controller I am useing is from stepperworld it is the FET3 Cruiser package.It is running at 12 volts.I figure it can go about 14 ipm max the way it is settup right now.
My question is this:Is there a way I can use the handheld torch with my current settup.How do they normally start the torch on a plasma CNC?I have the ability of turning the spindle on through the program, could this be used to start and stop the torch?I know I would need a THC.I have read that most CNC plasma cutters are water cooled.Could I get away with not being water cooled.I do not know if 14 ipm would be fast enough,but I could step up to 36 volts.That should get me about 28 ipm.I guess I could even go with a 10 tpi lead screw if I had to,that would get me 40 ipm.
If anyone has any tips or information I would greatly appreciate your help.
Thank You:Jim
