The documentation I have my my spindle wizard which has the same gear box doesn't recomend 30w or atf. It recomends amga #5 ep....which makes a lot more sense.
If you really want to get fancy with it you could add some of the dow corning molykote m gear guard dispersion. That's the lube the spindle wizard uses for the tubular ways on the fancy position wizard table. It's made to be added to gear oil though. You really can't be moly additives..and it's 10%. |
