Old 05-03-2008, 06:13 PM
metalworkz's Avatar
metalworkz metalworkz is offline
metalworkz is on a distinguished road
Did you try searching the name using a wildcard for the file extension(ie Unicodedlg.*) This will probably find all files with the Unicodedlg name and list them. I ran it on mine and found the file I had renamed as Unicodedlg.txt. If it finds the file that Chad named above you can just change the extension to .txt and this should keep it from executing nad causing the server problem. Hope this helps you solve the probelm.
Regards,
Regards,
Wes
