Old 05-03-2008, 06:30 AM
ger21's Avatar
ger21 ger21 is offline
The G201 will only draw 2/3 of the motors rated current, just a little over 2 amps in your case when wired in series. And about 4.2amps in parallel. You don't add the phases together. If your looking for high rpm's, you'd probably get better performance with a 48V power supply and parallel wiring.
