The board is already on it's way back to Jeff. Hopefully it is not as bad as I think!
As per your reply, I just finished checking my mill, since it already works, and as you said, I will find a pair of wires when OHM'ing,
So I checked the Lathe, and found the same thing. Now, if I had one of those wire's crossed, meaning an A/B instead of A/A+ would that pop the controller board?
I do not want to go through this again, and want to be 100% sure I have things right.
Thanks for your help, that seems to clear things up a bit.
Smitty |
