Like I said, I use a synthetic motorcycle oil. Its at 10w-40. The first time I used it I could actually tell the difference in sound, the gears were quieter and ran smoother. I just use a basic pump oil can and put a bunch through the oil ports. U can also repack the spindle bearings with a grease if you take them apart, which is not recommended. Then you can pretty much forget oil. |
