a number of questions regarding plastic/nylon/delrin-like materials...
i have a couple scrap pieces of a product called 'weatherguard' (? i can't find much of anything like it googling), as well as more pieces of a product called 'Starboard', and lastly a number of more scraps of a product called 'Azek'.
Azek is an exterior grade pvc material that will do for certain pieces of a homebrew cnc, but i have no idea how it will take to tapping... (seeing as how i am tapped out of taps; i'm still unsure what sizes i need)...
following is a quote from a site about 'starboard', not sure how it will take threads, either; it certainly has a denser, slippier feel to it than the Azek:
STARBOARD
TPI is a Master distributor of KING STARBOARD® products. This polymer sheet material has become the plastics standard for use in weather resistant marine construction. Used extensively to replace teak, select hard woods and treated plywood in hundreds of applications.
King StarBoard®
“The preferred material choice for most boating manufacturers”. We stock it in full sheets. You cut, rout and drill it just like wood into any kind of part you need. Available in 1 sheet size and 5 thicknesses. Choose from 6 colors - Dolphin Gray, White White, Sea Foam, Black, Sand Shade, and Light Gray. Call us for a quote and minimums on custom colors to match specific gel coat colors. For the best finish we recommend that you cut it with a standard fine tooth table saw and router the edges smooth. Available sheet sizes: 54" x 96" Sheet Thicknesses: 1/4", 3/8", 1/2", 3/4" and 1". Shipped with protective masking, one side only.
the 'weatherguard' felt even denser and almost greasy, compared to the azek and starboard...
does any one have experience machining these materials, and do they take to tapping readily ? would the 'dense', 'greasy' polymer stuff substitute for delrin ?
thanks
charley
charleyy@alltel.net
eof
