Paul,
A good one to use is ISO G-CODE. There are a few ISO posts ie: modal and non modal but try the one that comes with the install that just reads ISO_GCODE as its file name, if you are still having problems, send me a copy of your posted file and I will help you fix the problem.
__________________ "A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
