Old 05-01-2008, 07:17 AM
Nitroghost's Avatar
Nitroghost Nitroghost is offline
Nitroghost is on a distinguished road
Originally Posted by chazmtu View Post
Hi Nitroghost,
What do you mean by when it works? Do your motors stall? Does the system not start at all? Might hold a clue as to your problem.
Chuck
the system worked until i started to try and tune it. before when i tried to run the road runner sample the motors would stall at different points in the run. now it seems that i can sometimes get the motors to jogg when i do it manualy. i have tried to set the acceleration down almost all the way, and the velosity at 15ipm. i don't know how to set the power to the motors to anything other than what the the power supply was set at out of the box and what the drivers were set at out of the box as well. as you can tell i am not haveing to much luck at getting the motors tuned up. sometimes i can get the motors to jogg but only one way. what i mean is when i use the manuel jogging keys in Mach 3 they will only go to the positive side unless i click on them a couple times. i hope i am not to confuseing.
Jim
