Old 08-15-2004, 05:18 PM
Dan S's Avatar
Dan S Dan S is offline
Mad scientist
Dan S is on a distinguished road
Ok, I got another question. If I upload this zip file to the download section can I go back and change it? Because I think I might want to add a g code file to it later.
The zip file contains a dwg, dxf, and a readme. The smallest radius is 0.25” so they can be milled with end mills up to 0.5” in diameter. The mounting holes are sized for standard #10-32 allen bolts.
Kong:
As the files are now, there is 1.75” of clearance. If you need more clearance than that you must have some big wrenches.
Ger21:
Thanks for the info. I have 15/16” of clearance, so I think I’m good to go.
Dan Sherman
