I have no idea on the distance you require, but I do have a quick tip! Check your distance between the rear bracket mounting holes, and the joining holes on each side so there is enough clearance to get a decent size allen key in there. I have a similar bracket on my machine, and the allen key is a tight fit - possibly too tight.
Hope it helps
