Old 04-28-2008, 11:17 AM
seanreit seanreit is offline
seanreit is on a distinguished road
Can Bobcad be coaxed into making gcode for a 4 axis hot wire machine?
Supposed you have two rectangles parallel to each other in bobcad that are parallel in the z plane say 10 inches apart in x. Lets give them 10 inches of Y and offset them in Y by two inches.
Can the gcode be written in such a way that on the left rectangle all Y movements will be written as an A movement and if the Right rectangle is half the size in Y as the left rectangle, all Y movements there will be done at half speed as the A movements on the left rectangle.
It would be very helpful to me if bobcad can write G code in such a way to run a 4 axis hot wire cutter, the current programs out there are not working for me in a way that I can get what I want. I can draw it in bobcad, but have not had any luck figuring out how to write the G code.
