Bigz1 wrote:
"The only disadvantages I see with it are:-
It jogs at half speed when using one axis.
Macros/hotkeys cant be assigned.
Not all the buttons are released."
1. To make things clearer I am NOT using keygrabber associated with Lee's plugin. just the plugin.
2. if I want to jog axii faster I press several clicks on the left shoulder button (or the right button to decrease jog %). See the changes by hitting your TAB key on your keyboard.
3. Not using keygrabber associated with a "Screen modifier" in this case will not let you (I think) assign Macros/hotkeys to a specific button i.e you just use the specific menus under each button in Xbox plugin Config Mode.
This is anyway how I use my Xbox360 for Mach3Mill. I USE IT NOW ALSO for Mach3Turn WHICH I COULD NOT DO WITH MY CHEAP GAMEPAD SUCCESSFULLY.
Everything is set up as for Mill config and has the same behaviour except for the spindle button. But here I think I know the fix and will try, later today, to assign a different hotkey <S> to the spindle button by modifying with screen4.
Michel |
