Yes , Jim I cut out a couple of pieces.. Cut quailty was ok! 1/4 plate , 130 volts , 60 ipm
I was not sure about the rest of the settings , I think i had the toggle to manual , because torch height was allways the same... Not sure how to set up piece height yet... I do know it is suppose to be 1/2 higher than cut height.
I will go down to the shop later and try cut some 2" x 4" x .125 tube with my logo .
Should the plasma unit amps be turned all the way up and all settings made on the height control?
I am using t60m torch , will try these settings Arc volts 134 , Pierce Delay 0.50, 98 ipm
Is there anything else I should be looking to do? Thanks Dennis |
