We just put together a CNC router that is posted else where on this site and we had the same problems. We use a program called design CAD for all our drawings, then save it to DXF. Then we import it to lazy cam to set it up for G-code and then import it to our Mach 3 and that is were the problems started. We had the same problems you are having. Here is the fix Remove Lazy Cam and go with another software. We switched to V Carve and the problems are gone. We still have a small problems once in awhile, but nothing like before. I tell the guys in the shop ESO "equipment smarter then the operator"
Red |
