  #11   Ban this user!
Old 04-22-2008, 08:07 PM
BSims66173 BSims66173 is offline
BSims66173 is on a distinguished road
Micsit1, I switched the shuttles between the Tormach mill and my cnc router and the results were the same. The contour shuttle and the Tormach shuttle had the same results as before. The problem must be in the Mach3 system. I will have to work on this some more to see if I can get the contour shuttle to react as smooth on the router as it does on the mill. May have to contact someone at Mach for help. The Tormach runs a version of Mach3 designed specifically for tormach. I may see if I can adapt it to run the router and see what the results are.
Barry
