One thing that I found to help alot is make sure the leadscrew isnt binding up. You may have to slot the holes in the mount on the right end of the machine. While I was messing with mine I also drilled oiling holes in both of the blocks. Mine very rarely does it anymore since I installed the 5" chuck. It gives it enough flywheel effect to take some load off of the board. |
