Hi Fellas,
I am new to CNC and am knocking together my first rig.
I have a large Baker bench drill. For now I'm trying to set it up so that it drills perfectly straight holes. I can adjust the x angle of the work holder, but the y angle is fixed. It has an el cheapo vice mounted to it. Do you experienced guys have any particular methods that you use to set things as straight as possible?? Or is it just a matter of trial and error?
Also, how do you mount your vice to the work holder? (I know the obvious way is with nuts and bolts but this is a little inconvenient when you want to move it all the time.)
Cheers guys,
Paul
