Thread: Need Help! Haas VF2 Door Switch
Old 04-15-2008, 10:20 PM
omy005 omy005 is offline
omy005 is on a distinguished road
Originally Posted by wynepro View Post
I have a haas VF3 about a 1995 model, I tried the above method to override the switch and when I go back to the setting (51) it shows the interlock is off but when I try to run a command in MDI it still comes up with "Door Open".
Could I be missing something?
BTW the command line is as follows, G90 G00 G54 X0 Y0
Go to your diagnostics page and look a the the "DISCREAT INPUTS" the one that says Door/Sfty Switch. This should go 0 & 1 when you open and close the door. Some times the switches can stick and also the strikers can vibrate down and not make contact with the switches. Hope this helps.
Andrew.
