Originally Posted by Claude Boudreau I get crop circles too
I cant find a General menu in the Setup menu (Cam side , Ver.21)
dont see Max circular arc movement anywhere... |
Claude Boudreau,
Open a new file, Click on the Milling Machine Icon or go to the Special/NC-CAM in the Main menu. You will find "Insert NC" choose a Machine Control Configuration like Fanuc6M Simple
Another window will open on the left side.
At the top in the Main Menu go to Setup then from the drop down menu select "Driver". Now go to the General Tab and toward the bottom you will see "Max Circular Movement" Full>Half>Quarter
Chose the one that your control is capable of doing.
Do not forget to Save the file as a blank file if you have no Drawing Opened.
