Old 08-07-2004, 08:47 AM
HuFlungDung's Avatar
HuFlungDung HuFlungDung is offline
Moderator
"I can hear the ball bearing jumping and popping" doesn't sound too good. It could be an indication of one (or more) balls that are too large. If this is not a precision ballscrew, you may not have a lot of choice in what is acceptable, but don't expect it to ever "wear in". It won't.
I don't know what kind of double nut locking device you are using, but just jamming them against one another is not the correct method of preloading. They should be spaced with a precision spacer and then locked rotationally together. In this manner, the spacer controls the preload.
