well simple test just type in #100 in MDI and start, if you don't get an alarm then machine has macro option. However double check with your manual, because some machine has difference format. For example, Fadel is v1=xxx and for Seimen @K1=xx so check your manual for further detail.
I havn't use Okuma before, so I don't know.......
__________________ The best way to learn is trial error. |
