Hi Guys
Ive not had too much luck with making pcb's, I either can't get the board flat or can't find the right bit.
Im working on a spring loaded engraving tool, but it's taking a while.
In the meantime I would like to use the mill with an etch resist pen, but how do I export the board from eagle to dxf, and how to I convert that dxf into gcode, so it basically draws where the tracks should be (and fills them in).
Any Thoughts?
DJH |
