Someone emailed me the Onsrud router bit guide in PDF format. Its got a LOT of information so I guess I should read it before asking any more questions. At first glance, though, it appears to be what I needed.
I plan on using a trim router to cut and engrave both wood and acrylic. For that primary usage I think I need to select a couple of good striaght bits (cutting) and V-bits (engraving). I may also pick up a 1/8" ball endmill for playing with some 3D created in BobArt.
If you use a home made CNC router with a trim router and have done any of the above with success, please post what bit(s) you are using. Thanks!
__________________ Chris
buckey29@yahoo.com |
