If you are running Mach2 then you must have XP. Do you you use the internet with this PC? Do you have a Virus Scanner installed? Reloading XP doesn't take very long and solves a lot of problems. Just make sure you have your serial number. I had a similiar problem that went away after removing McAfee and reloading XP. Didn't even have to re-install Mach2 after reloading XP. You may need to re-install some drivers but mine came right back up. If you are not very computer savy then you might have someone that is do it. |
