Old 08-05-2004, 05:15 PM
RandMan RandMan is offline
RandMan is on a distinguished road
I haven't used my VM 5 in a while since I switched to OncCNC but have you tried setting the vertical distance setting in approach motion box of the Entry/Exit tab on the 3 axis pocketing screen ? As Hu suggested the feeds&speeds for the plunge and approach speeds are configurable separately from the engage settings so you might be able to safely crank those up if you can't minimize the vertical distance setting.
