  #12   Ban this user!
Old 08-05-2004, 07:48 AM
arvidb arvidb is offline
arvidb is on a distinguished road
Originally Posted by RXTurbo
*snip*I was thinking of the V thread from an accuracy point of view - I can buy ground threaded rod and a tap to cut the delrin. To do this as an Acme thread I would have to cut the thread on both the lead and the nut. This would also mean having to grind tools to do the job - surely a V thread and tapped nut would be more accurate than a lathe cut thread?
Why can't you buy ACME/trapezoidal screws?
Where is ground V-threaded rod used? I thought V-thread is intended for fastening and then I can't see what use it would be to (precision) grind it?
BTW, V-thread is a lot less efficient at transfering motion than trapezoidal. That makes sense if you think about that it is meant for fastening things (preventing motion).
Arvid
