Thread: Need Wizard
Old 04-05-2008, 01:24 PM
LeeWay's Avatar
LeeWay LeeWay is offline
LeeWay is on a distinguished road
I agree and there likely is something somewhere. I was having a little difficulty with mach turn, so it may do what you want. I had 6 specific sized bushings that I make for various models of my blade guards. I needed them fast once I cnc'ed my little lathe. I did all 6 with edits to get what I wanted in about 3 hours. Some of that was actually running the lathe to test the code.
As I mentioned, these are very simple bushings. They get a through hole first and then get machined and cut off with a parting tool.
Like for the router and mill, I'm sure it will take some time to get Mach turn down. Does it not have a depth of pass?
My biggest trouble is the axis letters I think. I motorized my tail stock to drill and I call ity Y. X is my cross slide and Z is the lead screw.
I am actually using Mach mill instead and just stole some peck drilling routines for the tail stock from Sheetcam on my mill. The other two axes were basically hand coded with teach.
Lee
