RE:- Use of Routout CNC | | Hi Kirk,
I don't see any reason why you could not run your cutting torch with the software. I personally have not used a plasma cutter, but it should work great. The only drawback at the moment is that it can only load HPGL/PLT files, although you can use any program like Corel Draw so you can then inport almost any file type and export to HPGL. I am currently working on the software to except DXF and G-Code and additional documentation, but this will take me approximately 6-8 weeks. If you need any help regarding the setup please do not hesitate to contact me either by phone or by email.(both of which are in the help file in the routout viewer.)
Best Regards
Mike Gaylor |
