Thread: Need Help! G100 communication problem
Old 04-02-2008, 10:16 AM
henkb henkb is offline
henkb is on a distinguished road
Hi Clockwork,
Thanks for your reply. When I saw it I thought that’s it! In my configuration the Default FPGA =0 and in yours it =1! So I changed it to 1 and tried again. but no luck. Both the Grex loader and Mach do not see the G100.
When I start the Grexloader program and switch on the G100, click Discover several times during the first 10 seconds nothing happens, the g100 is not found. The Run led has not come on : so to me it seems they are communicating. If I then enter the IP address manually and press Launch, a internet explorer opens and shows the firmware upload page.
Apart from the FPGA=0 setting everything else is as you described.
If I click the run button the RUN led comes on as it should. So that seem to work normal
I even set the IP address to 192.168.1.1 to see if that would help but no luck.
I just cant understand why I get the setup page in IE (surely it must communicate with the G100 to do so) but cannot connect with the grex-loader or Mach.
On my G100 there a written label that says E7. Don’t know if this means anything to anybody?
Well I am open for bright ideas………
Henk
