Old 08-02-2004, 04:29 PM
CRFultz CRFultz is offline
Gold Member
CRFultz is on a distinguished road
Here is the motor mount and the simple end bearing block.
I will end up cutting off the wings on the motor mount. my ballscrew is only 36" with 3" turned down, so I ran it up between the center rails. I had already drilled the 1/4 inch holes on the side so it hooked up with the tslots in the extrusion...downside...I'm sure I will have misalignement somewhere...tweaking will be called for.
Aspire, VCPro, PhotoVCarve, Cut3D, Mach3, Home built CnC.
