Start by calling up the local agent for your machine. Describe the problem to them and then see if they will give you some pointers to start with. Do your checks and if no good call the agent and try again. I've been doing this for over 15 years now, and although my knowledge is far from ideal regarding cnc's, I can now fix most problems that arise with the machines I am working with. (I also now have some reliable and good contacts around the place that I can call for advice) Good luck! |
