The Text must be part of a solid to have caps on it (as far as I can tell), Since this is a simple curve what I did was Just Like before and got pict number one, Then I made the same sphere .1 higher in the Z all other dims the same and got pict number two, Made the text .1" tall, then I did a boolean subtract. Made the same sphere .050 lower in Z for a 0.050" tall text and did a boolean subtract. This is for a simple curve like you described before, There are also several other ways to do this but for what I understand you wanted this was easiest for me. |
