Please tell me there's dye in that water! Is the algae really that bad?
Plasma Quench from Koal Industries is the stuff I've seen mentioned for controlling rust, odor and algae. A cheap alternative for algae control might be Bromine, a biocide used for pools and spas, similar to chlorine without the smell. If you want/need the corrosion control as well, there are lots of chemicals available for treating boiler water and/or cooling water. Plasma Quench would be the best solution, but I can not find a source for it other then the manufacturer, and they have not responded to my RFQ. |
