In CAM, output the proper code. That is, have it go to the proper depth of cut as if you were really cutting metal. On the machine, edit the work coordinates (where you set up your XYZ on the part) and bump the Z wear offset up enough so that your deepest cut is up above the metal.
__________________ The Machinist's Chatroom
http://machinechat.freehostia.com/ |
