How to hold small workpiece? | | I have to mill few hundred of small blocks out of ABS sheet using 2D prog. Part is fairly simple and size is about 6mm cube having little corner radius. I'm trying to machine multi-pieces right thru out of a large sheet but problem is part moves and gets damaged at the end of the cut because no clamping left. Could someone advise the best strategy to machine without damaging the parts. Thanks in advance.
Kevin |
