fixturing and multi-sided coord sys | | I'm seeing a conflict with the use of multi-sided machining and fixtures in SolidCAM, can anyone give me a hint here?
I build an assembly in solidworks of the solid model of the stock, the part to be machined and the vise (see image). I'm able to set the vise as the "fixture", the stock and target as such, and to machine the top orientation.
I can define multi-sided coord sys, but the vise is in the way when I try to cut the bottom (as you would expect).
It appears that if I'm using a fixture in my cam part I can't have machining definitions for multiple part orientations - but that doesn't make any sense.
What is the best way to proceed? |
