Profile | | Hi, friends
I am a cnc owner and face some problem
I uses Solidworks for designing and solidcam for machining
I have also some knowledge about ArtCAM Pro
I design a simple flat ring in Solidwork having hole size 19.95 mm while I generate g-code using solidcam and machining the part there is some variation in final part, the final hole size is 19.75................... I use simple profile fiture 0.5 mm offset for final cut............. I select Fanuc4ax controller
While I create same ring in ArtCAM there is no difference and the hole size is same as drawing 19.95
Material: Brass, 2 mm Thickness
Machine Spindle: 1.2 KW, 24000 RPM
Machine Drive: Servo Controler
Need some changes in SolidCAM software settings..... which setting I don't know
Anybody solve this problem
Have a Nice Day ! |
