ok i diid some more work on this unit and found that i can probably mount the motor if i machine down the face and use the four bosses in red, the shaft is still questionable since it has a helical gear machined onto it to use it i woul probably need to make some sortof adapter, after sleeping on it it seems that this motor would be suited to use as a spindle, with a few bearings, |
