Old 03-09-2008, 10:42 PM
BrassBuilder BrassBuilder is offline
BrassBuilder is on a distinguished road
Originally Posted by metalworkz View Post
Hi Mike,
If the only thing to move is one side of the drawing I think I would just delete the line extend the 2 ends and redraw the line for the side. If you are using version 10 there is supposed to be an option for changing lengths etc. What are you working on if you can tell us, and did you get it done today? Just curious.
Regards
Yeah, that is pretty much what I did.
I'm making three cylinder heads for a Cummins 400 model engine (non-running). I'll attach a drawing of it. I don't know if I have all three layers turned on in the attached drawing though. There is the cylinder head layer, the bolt head layer and the rocker housing layer. I am hoping to start milling the rocker housing layer on Monday. This is the blue lines.
That brings up a question...ummm....forget it...I'll start a new topic on it instead. It is about milling a lip around the bottom.
Mike
