Old 03-08-2008, 06:26 PM
vdawg2344 vdawg2344 is offline
vdawg2344 is on a distinguished road
Macturn 250-W help with G52
What you need to do is when you touch off the tool on the presetter, have it at the angle you are going to turn (face, turn whatever) at. Use a seperate offset for each angle you will use that tool at. G52 is for milling tools, not turning tools. I wouldnt even use it with turning. It rotates the tool offset based on the angle you have the B axis at. It cannot take into consideration the nose radius you are using.
Good luck!
