Hi paul,
just reading your note, what type of problems are you having? as we have 2 evo 50's and a brand new evo 70 lineer.So we have had our fair share of problems to.With the 50 lineer we had the very first one in the country so i think they used us as a test bed ha! . the main problem we had was the tool changer kept getting stuck every now and then.It turned out to be the wrong parameters had been set in the software, works fine now.And the other problem is having to keep getting the tables to be calibrated every now and then i.e when you spun the tables up at an angle they they didnt go where they should error of .05 -.08 of a mm.Mind you our m/c's are run 24 hours a day.
So when we got our new 70 evo leneer we had learnt our lesson and we ordered it with the new quick set feature which is a bit of software that automatically recalibrates for any errors, again first one in the country to have it. just saves us having to call in a DMG tech guy to do it, operator now does it. |
