I have a Bridgeport that is running on Mach3 on win xp.
I am having problems with the wizards.
Any wizard i try will not post a g-code or return to the program run page.
I fill in all the settings pushing enter to make each change.
When I want to post the g code the sreen locks up.
If I push exit it will exit but after quite a bit of time.
I can get the circle cut wizard to work once each time i start Mach3 if I don,t reset Mach 3 but go to the circle cut wizard,fill in settings,post g-code then exit the program is there and will run after I reset Mach3.
If I try anything else it just locks up.
this is the trial version of v2.63. |
