Pocket Milling - Less Material | | I think what I'm after is called "less material" but not sure. I've tried changing every variable and non of them seem to accomplish what I'm trying to do. Here is what I mean:
Let's say the top of my part is at Z0 and I want to cut a particular pocket .300 deep with .100 cuts. After the first .100 cut the toolpath takes the end mill back up to safe Z plane then goes down slowly to make the second .100 cutt. After that it goes back up to safe Z and then down for the next .100 cutt, etc.
The problem is the wasted time cutting air between cutts. I don't want/need the cutter to go back up to safe Z when it just has to come back down (slowly) to make the next cut. I would think VM being such a formidable program would recognize the fact that it just cut the material there so it doesn't need to cut air slowly on its way back down.
I've tried every variable in the pocketing parameters. What am I missing?
Mark |
