Thread: New Machine Build Beginnings of a 3 axis machine
Old 03-02-2008, 03:17 AM
razzledog razzledog is offline
razzledog is on a distinguished road
Hi Guys... I have decided to construct a small 1 meter by 600mm 3 axis CNC. So far I have organised the bed frame from 125mm x 8mm aluminium channel and settled on 16mm hi tensile Samson rods for driving (what I call) the 'bridge' supported by 6202 ball bearings in plates at each end. I have set a goal to have this machine up and going by Christmas this year
A couple of questions I have....
1. Should I use a stepper for each lead screw or connect them via a toothed belt to a single motor?
2. Will a decent motor have enough grunt to turn the screws?
Thought I'd get the mechanics sorted out first and worry about the electronics later.
I realise it's a steep learning curve, although I have successfully turned a wood lathe into a metal lathe and made a small mill by fitting a cheap Ozito router to my drill press, although usually I only build cameras.
I posted this on the OZ clubhouse without much reponse.......
